The problem I am having is that once the oven reaches the desired temp. it will not turn back on. But if I set the temp at 425 and higher it will maintain the temp. The broiler always?
Hi Francis,
What was shown on the display when the oven did not turn back on?
Was it blank?
What did you mean:"The broiler always?"?
Hi Gene, yes the display remains blank and I meant that when you use the broiler it always works and stays on. Thank you
Francis, Most likely the problem is a bad control board which has to be replaced. - The part number for the control board is AP3792697 If you can not use the old overlay, the part number for the overlay is AP2025084 Gene.
