markjenna
#1 Posted : Monday, December 28, 2009 6:54:33 AM(UTC)
markjenna
When it gets cold out my freezer stops freezing. I have the frig in the garage as a second one. During the summer all is good. Once it gets cold out everything defrost. Once the temp gets below like 40 my stuff starts to defrost. If I turn the heat on in the garage it freezes again. As long as the heat is on in the garage all is good, but I don't want to run the heat all winter.... Any thoughts?
#2 Posted : Monday, December 28, 2009 3:18:04 PM(UTC)
No one domestic refrigerator will work if the ambient temperature is bellow 55°F. Only Frigidaire designed a special heater which can help to use a refrigerator in such environment. I can not guarantee it will work with your refrigerator, but it is inexpensive and you can give it a try. It comes with the installation instructions.
- The garage refrigerator heater Part number: AP3722172
