Hey all.
I have read through a bunch of problems but none seem to match mine. All it needs is power and it immediately starts heating up and will not turn on. It gets so hot you cant even touch it. About 1 year old, checked vent and door switch. We are the first to live in the home, so don't think the wall vent is the problem. I'm just glad I checked 1 night before bed, because the room it is in was a good 20 degress warmer than the rest of the house due to the dryer heating up. Any suggestions? I had to unplug it to cool it down.
Thanks in advance
Scott
THIS FORUM IS DEAD!!!!!!! |
![UserPostedImage](http://c1.ac-images.myspacecdn.com/images02/113/l_9ed101b191fe4907b82b0d38a5b87d54.jpg) Took apart the heater coil and some of the plastic holders were broken and the coils were resting on 1 another and the frame. Here are a few pics If this would cause the getting hot problem I can understand, but the dryer won't turn on when pressing the start button as well. Is it some kind of fail safe? Can I unhook the coil and test to see if the dryer will turn on with the switch so I know that is ok before waisting $$ replacing this part first. Thanks in advance Scott
If the internal lamp was working, is it still working? If not you may have lost half the line and the 120 side that runs the motor is missing. Best to check the power at the plug to make sure you have L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and make sure that all the wires at the units terminal strip are OK. Not a bad idea to check for power here.
The most likely cause would be the thermal fuse Item 18 in Section 3. It does sound like you do not have a meter so you could check it by doing the following. Unplug the unit. Disconnect the wires at the heating coil, take note where they attach. Tape them up so thay cannot short to the frame or each other. Remove the wires from the thermal fuse and short them together. Tape them up so they cannot short to the frame. Plug the unit in and give it a try,
While yo have it opened up check all rollers, glides, belt etc. for wear, You might as well do an overhaul on it, also if it needs lots of parts it may make more sense to replace it.
If you do decide to repair it, give the interior a good cleaning including the blower wheel. Also a good time to clean/check your vent system. |
