Betterbait
#1 Posted : Saturday, December 26, 2009 1:31:33 PM(UTC)
Betterbait
Hey all.
I have read through a bunch of problems but none seem to match mine. All it needs is power and it immediately starts heating up and will not turn on. It gets so hot you cant even touch it. About 1 year old, checked vent and door switch. We are the first to live in the home, so don't think the wall vent is the problem. I'm just glad I checked 1 night before bed, because the room it is in was a good 20 degress warmer than the rest of the house due to the dryer heating up. Any suggestions? I had to unplug it to cool it down.
Thanks in advance
Scott
#2 Posted : Saturday, December 26, 2009 2:51:41 PM(UTC)
Here are your parts. They are for a SQ1, I could not find info on 5Q1.
Replacement parts for WHIRLPOOL RED4340SQ1 29" Electric Dryer | AppliancePartsPros.com
Here is your wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Sounds like you have a grounded element, the heating coil has sagged or broken and is touching the case/frame. Often you can see this by inspecting the heater assembly.
Best way is to check it with a meter.
Unplug the unit.
Unplug both wires from the heating coil, should be around 10 ohms.
Measure from each coil connector to the case/frame, both should be infinite ohms.
Betterbait
#3 Posted : Sunday, December 27, 2009 3:34:19 PM(UTC)
Betterbait
UserPostedImage
Took apart the heater coil and some of the plastic holders were broken and the coils were resting on 1 another and the frame. Here are a few pics
UserPostedImage
If this would cause the getting hot problem I can understand, but the dryer won't turn on when pressing the start button as well. Is it some kind of fail safe? Can I unhook the coil and test to see if the dryer will turn on with the switch so I know that is ok before waisting $$ replacing this part first.
Thanks in advance
Scott
#4 Posted : Friday, January 1, 2010 4:11:17 AM(UTC)
If the internal lamp was working, is it still working?
If not you may have lost half the line and the 120 side that runs the motor is missing. Best to check the power at the plug to make sure you have
L1 to L2 should be 240 volts
If OK
Unplug the unit and make sure that all the wires at the units terminal strip are OK. Not a bad idea to check for power here.
The most likely cause would be the thermal fuse Item 18 in Section 3.
It does sound like you do not have a meter so you could check it by doing the following.
Unplug the unit.
Disconnect the wires at the heating coil, take note where they attach.
Tape them up so thay cannot short to the frame or each other.
Remove the wires from the thermal fuse and short them together.
Tape them up so they cannot short to the frame.
Plug the unit in and give it a try,
While yo have it opened up check all rollers, glides, belt etc. for wear,
You might as well do an overhaul on it, also if it needs lots of parts it may make more sense to replace it.
If you do decide to repair it, give the interior a good cleaning including the blower wheel.
Also a good time to clean/check your vent system.
