bacnberger
#1 Posted : Thursday, December 24, 2009 8:43:33 PM(UTC)
bacnberger
I have a Ge side by side refrigerator that started to not cycle on sporatically. It can run fine for a day or a few weeks but then it will just not turn on. If I turn the temp control to off and then back on it will start running again. Sometimes that will not work and if I manually move the defrost timer one or two clicks it starts. Do I need to change the timer, the temp control, both or something else.
#2 Posted : Friday, December 25, 2009 3:54:39 AM(UTC)
Replacement parts for TFX27ZP models | AppliancePartsPros.com
Since moving the defrost timer always works I would replace that first.
Sounds like it is hanging up right at the end of the defrost cycle.
