Replacement parts for FRIGIDAIRE PLRU1777DS0 Frigidaire/refrigerator | AppliancePartsPros.comFirst make sure the evaporator fan is running.
Next, remove the cover so that you can get see the evaporator coils.
If they are heavily frosted/iced up to the point where the fan cannot pull air through them, you have a defrost problem.
Note: do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 3 ) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 3 ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 20 in Section 3 ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
