2 Pages12>
mountain287
#1 Posted : Wednesday, December 23, 2009 10:48:59 PM(UTC)
mountain287
The control panel on my Maytag QuietSeries 200 is unresponsive, with the exeption of allowing you to select the cycle. The start button and delayed start buttons do not work.
I cleaned the control electric panel connectors AP4411619, which connects to the control panel AP4364553. It didn't work.
I suspect the control electric panel may have gone out. Suggestions?
#2 Posted : Thursday, December 24, 2009 1:10:32 AM(UTC)
A Model Number may help others help you.
The problem could be either of the devices you listed.
With a model number perhaps a tech sheet is available with the pin-outs for the control panel which will allow you to check the switches.
Then at least the odds of you replacing the correct part the first time are better.
mountain287
#3 Posted : Thursday, December 24, 2009 7:24:07 AM(UTC)
mountain287
Sorry, a model number would probably help. MDB4651AWB.
I have good news though, apparently I had forgotten about the 3 year extended warranty I had purchased. The beloved repairman is on his way.
#4 Posted : Thursday, December 24, 2009 8:11:43 AM(UTC)
That is good news
Merry Xmas
jefflouis
#5 Posted : Thursday, December 24, 2009 9:22:39 AM(UTC)
jefflouis
Originally Posted by: denman Go to Quoted Post
That is good news
Merry Xmas
I have that exact problem with a
MDB9750AWS and I am out of warranty!!!! PLease help!
mountain287
#6 Posted : Thursday, December 24, 2009 10:36:36 AM(UTC)
mountain287
The repair person ordered a control electric panel (circuit board) and the control panel (push button panel). He couldn't determine which part was broken, so he ordered both.
jefflouis
#7 Posted : Thursday, December 24, 2009 10:51:56 AM(UTC)
jefflouis
that's about $220 in parts... I may consider buying a new one. mine is 4 years old. it's just a shame that these things dont last longer. I've already replaced the latch a few months ago and now this!
Please post the outcome. thanks and Merry Christmas!
#8 Posted : Thursday, December 24, 2009 11:45:30 AM(UTC)
jefflouis
Here are the parts
Replacement parts for MAYTAG MDB9750AWS Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/m...ibrary/docs/16026391.pdf
Try the following first
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If this does nothing the normal way to troubleshoot it is to check out the keypad switches with a meter. If it checks out OK then the most likely culprit is the control board.
swingineel
#9 Posted : Thursday, January 23, 2014 5:34:36 AM(UTC)
swingineel
Hello, i have this same problem. I have a multi meter, but am a sort of novice on how to use it. Could you be more specific in the check procedure to what I am looking for in normal readings?
Thanks!
#10 Posted : Thursday, January 23, 2014 6:56:57 AM(UTC)
swingineel
Is your unit the same model?
Need that so I can look up the tech sheet.
2 Pages12>
