I searched the form for ice makers overflows but can't find a good match. My situation is I just replaced the water valve because it appeared to be leaking. I now find that the ice maker refill times are too fast and causing an overflow . Cycle time seems to be 5-10 min then not for 30 mins. With the new valve, the leaks have been confined to the freezer bottom but within and hour but has now overflowed. HELP !
