mikeg1
#1 Posted : Monday, December 21, 2009 6:50:18 PM(UTC)
mikeg1
I searched the form for ice makers overflows but can't find a good match.
My situation is I just replaced the water valve because it appeared to be leaking. I now find that the ice maker refill times are too fast and causing an overflow . Cycle time seems to be 5-10 min then not for 30 mins.
With the new valve, the leaks have been confined to the freezer bottom but
within and hour but has now overflowed.
HELP !
mikeg1
#2 Posted : Monday, December 21, 2009 6:53:25 PM(UTC)
mikeg1
freezer temp 0-2 F
