ChadJ
#1 Posted : Monday, December 21, 2009 11:22:08 AM(UTC)
ChadJ
We had our oven on last night and flames, sparks, and a buzzing sound came from inside the oven at the bottom left (oven element?). Now both the oven element and broiler elements don't work. All burners on the stove top work fine and the clock works fine.
Do I need to replace both elements or could there be another issue?
Thanks!
#2 Posted : Tuesday, December 22, 2009 4:34:36 AM(UTC)
Replacement parts for MAYTAG MER5555QAW Range - S/c F/s Ele | AppliancePartsPros.com
Here is a manual and tech sheet
http://www.servicematters.com/m...ibrary/docs/16025644.pdf
http://www.servicematters.com/m...ibrary/docs/16025645.pdf
By the sound of it the bake element is gone, it may have also taken out the control board or the thermal limiter.
Unplug the unit
Remove the bake element and check it with a meter, should be about 18 ohms.
I would also check the broil element, should be around 15 ohms.
Remove and check the thermal limiter, should be 0 ohms.
Check that all wires from the control board to the elements are OK.
The oven element will probably be shot, replace it if it is.
If the wires are good and the themal limiter is good but the unit still does not work, then odds are that when it sparked it blew the control board.
Thermador Dual Fuel Oven Element Replacement (Oven Repair (including Ranges and Cooktops))
by andyatthepond 2/2/2011 3:27:48 PM(UTC)
Broiler Upper Oven Element Replacement (Oven Repair (including Ranges and Cooktops))
by Auzzie 10/4/2010 10:29:14 AM(UTC)
oven element replacement (Oven Repair (including Ranges and Cooktops))
by tami01 9/30/2010 6:23:39 AM(UTC)
thermador oven element replacement (Oven Repair (including Ranges and Cooktops))
by FCarone 9/18/2010 8:09:07 AM(UTC)
by gloriasaw 11/27/2009 9:05:15 AM(UTC)
Oven element replacement 240v or 250v (Oven Repair (including Ranges and Cooktops))
by yoda@ui 10/10/2009 10:03:47 AM(UTC)
