panderson@identitysystems
#1 Posted : Monday, March 17, 2008 3:31:08 PM(UTC)
I'm trying to replace the igniter switches on my GE Stovetop but have no drawings to go by. I can't even figure out how to open the unit to get to the switches. Don't want to randomly start removing screws. Any suggestings/help?
#2 Posted : Tuesday, March 18, 2008 2:21:47 PM(UTC)
In order to access the ignition switches you have to remove all burners and the top panel.
- The part number for the ignition switches assembly is AP3185909
Here are the break down diagrams for the GE stove Model JGP932BEC1BB
#3 Posted : Tuesday, March 18, 2008 7:07:23 PM(UTC)
Thanks for the info. One other question. I see that the burners have 2 screws each but are also held down by the igniters. How do you remove the igniters(#154 in the drawing)?
#4 Posted : Wednesday, March 26, 2008 7:26:24 AM(UTC)
:( Part #AP3185909 (WB18T10176) isn't the correct part. Attached is one of the switches from the existing harness. I guess I'll be contacting GE directly to see if there is a recall. I have had continous problems with this unit almost from the beginning. Why they would have a non-waterproof switch virtually exposed to the cooking surface is beyond me!
File Attachment(s):
_0326101629_001.pdf (1,408kb) downloaded 12 time(s).
