I'm trying to replace the igniter switches on my GE Stovetop but have no drawings to go by. I can't even figure out how to open the unit to get to the switches. Don't want to randomly start removing screws. Any suggestings/help?
In order to access the ignition switches you have to remove all burners and the top panel. - The part number for the ignition switches assembly is AP3185909 Here are the break down diagrams for the GE stove Model JGP932BEC1BBGene.
Thanks for the info. One other question. I see that the burners have 2 screws each but are also held down by the igniters. How do you remove the igniters(#154 in the drawing)?
:( Part # AP3185909 ( WB18T10176) isn't the correct part. Attached is one of the switches from the existing harness. I guess I'll be contacting GE directly to see if there is a recall. I have had continous problems with this unit almost from the beginning. Why they would have a non-waterproof switch virtually exposed to the cooking surface is beyond me!
