I have a Whirlpool dryer that no longer heats to dry clothes. The unit runs but does not generate heat. Per your suggestions - I checked the circuit breakers to ensure they were not tripped. I made sure the dryer is getting 220 volts iof electricity with a multimeter. I checked the main terminal for any damage - couldn't see any. I checked the thermal fuse for continuity with the multimeter - it is good. I checked the heating element for continuity - it is good. I also checked the thermal cut-off for continuity - it is good. Still no heat. Any other suggestions?
Rank: Administration
Groups: Guests
