Discuss
No Dryer Heat
 in
Dryer Repair
Our Whirlpool dryer no longer generates heat to dry clothes? Which part is no longer working as intended? Related ModelsWhirlpool&
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Dryer Heat
  #1 (permalink)
Old 08-07-2007, 12:34 PM
Warren Warren is offline
Junior Member
Warren is on a distinguished road
Default No Dryer Heat
Model Number: LEN2000KQ1   Brand: Whirlpool   Age: 1 - 5 years
Related Models
Whirlpool LEN2000KQ1 29"electric Dryer
Whirlpool LEN2000KQ2 29"electric Dryer
Whirlpool LEN2000KT0
Whirlpool LEN2000KT1 29"electric Dryer
Whirlpool LEN2000LG0
Whirlpool LEN2000LG1 29"electric Dryer
Whirlpool LEN2000LW0
Whirlpool LEN2000LW1 29"electric Dryer
Whirlpool LEN2000PG0 29"electric Dryer
Whirlpool LEN2000PG1 29"electric Dryer
Whirlpool LEN2000PW0 29"electric Dryer
Whirlpool LEN2000PW1 29"electric Dryer
Whirlpool LEN3434AW0
Whirlpool LEN3624BN0
Whirlpool LEN3624BN1
Whirlpool LEN3624BN2
Whirlpool LEN3624BW0
Whirlpool LEN3624BW1
Whirlpool LEN3624BW2
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
  #2 (permalink)
Old 08-07-2007, 12:40 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Is there any heat at all?
If there is no heat:
1. Make sure one of the circuit breakers is not tripped
2. Make sure dryer gets 220 volts at the wall socket
3. Unplug the dryer and check the main terminal block for damage (this is where the power cord is attached)
4. Check the thermal fuse for continuity with an ohmmeter (fuse is number 7 on this diagram)
5. Check the heating element for continuity (heater is number 17 on the same diagram)
6. Check thermal cut-off for continuity (number 9 on the same diagram)
- Inexpensive multimeters (volt / ohm / amp, etc.)
Let me know what you find.
  #3 (permalink)
Old 08-07-2007, 01:10 PM
Junior Member
Default Absolutely no heat at all
One of the circuit breakers had been tripped. I switched it back on. Ran the dryer for 15 minutes. Still no heat. I checked the wall socket - that's okay. Perhaps the thermal fuse is dead?
  #4 (permalink)
Old 08-08-2007, 11:13 AM
Administrator
APP Team
Default
Warren, you've checked the first two items on the list. Now I would check the rest. I listed those items in order for a reason. You always want to start from the beginning, from the power source, and move on down. Thermal fuse could be bad, but check the terminal block first. It's the next link in the chain.
  #5 (permalink)
Old 08-09-2007, 08:38 AM
Junior Member
Default
I have discovered that there is a fan that needs to be removed to get to the thermal fuse (I think). How do I get the fan assembly off so I can get to the thermal fuse. Thank you.
  #6 (permalink)
Old 08-09-2007, 06:00 PM
Administrator
APP Team
Default
Warren,
Are you trying to access the fuse from the front of the dryer or from the back? The fuse should be easily accessible from the back. Unplug the dryer and remove the back panel. It's right on the blower housing.
Let me know how it goes...
  #7 (permalink)
Old 08-10-2007, 01:46 PM
Administrator
APP Team
Default
Warren, I'll post your email here:
I found the thermal fuse. I'm not sure what I'm trying to find. There seems to be no break in the connection. There are two wire connectors going into the white housing. There is a shiny black material (looks like hard plastic) between the two connectors. I don't see any indication that the connectivity is broken. Could it be broken within the white casing?
Warren
Warren,
You can't really check the fuse visually. Gotta use an ohmmeter (see link in my first reply). Since you can't see inside the fuse, you can't tell whether the wire is broken or not. Using an ohmmeter you can accurately check the fuse for continuity. Using the same meter, you can also check the heater and the thermal cut-off. You can purchase a meter from your local radioshack (or any electrical supply) or you can purchase one from us using the link above.
  #8 (permalink)
Old 10-24-2007, 06:01 PM
Leesa Leesa is offline
Junior Member
Leesa is on a distinguished road
Default
Hello,
I'm replacing coils on a whirpool dryer, and I was wondering if it's easier to access these from the front or back....do you have a diagram...LGN2000LWO
Hi Gene, hoping you could help me again.
I'm having no heating issues. The dryer works great and there's no heat. I've replaced the coils, ignitor and thermal sensor.....what now???
  #9 (permalink)
Old 10-24-2007, 06:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Leesa
To get access to all the parts inside the dryer, remove two screws at the lint screen slot and using a putty knife, push and pry the clip on each side in front of the top panel to release the holding clips. Lift up the top panel until it rests on the hinges. Unplug the quick disconnect plug for the door switch. Remove a screw from each side of the front panel. Pull the front panel up and toward yourself to release it from the retainer clips. Looking under the drum you'll find the idler pulley with the belt. Draw a picture of the belt that goes through the idler pulley onto the motor pulley so you will know how to assemble it back. Remove the belt and pull out the drum. Now you have access to all parts inside the dryer.
Good luck.
__________________
  #10 (permalink)
Old 10-25-2007, 08:45 AM
Junior Member
Default
By far the easiest way to replace the heater coil is from the back. Make sure your heating coil is bad before you buy and replace. I replaced several parts before I found the one that I truly needed. Unless you are positive your heating coil is bad - I suggest you go down to Radio Shack or electrical supply store and buy a ohmmeter. These cost $20-$30. You can check the connectivity for most everything including the heating coil.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 7 06-15-2009 12:12 PM
Dryer will run but not heat allansc Dryer Repair 12 12-28-2007 07:10 PM
Dryer won't heat dwh Dryer Repair 1 07-30-2007 06:35 PM
dryer heat karen Dryer Repair 0 07-23-2007 01:55 PM
