My freezer will not defrost on its own. I need to order and replace the control board. Does nayone know the cost of the part and where I can order one?
Thanks,
David
THIS FORUM IS DEAD!!!!!!! |
The Model number is PSF26NGPA BB
Thank you for your help. I was told by a GE "repair man" that it was the controller board. He said they fail all the time. He wanted $700.00 to replace it. When I said no, he offered to come back the next day and fix it for 400.00. He charged me $100.00 for the diagnosis... So honestly I am not sure of what is broken? He never took anything apart. He just looked at the fost on the back of the freezer wall.
The freezer does not defrost, that is all I know and I can only aford about $200.00 to fix it. I have been using a blow dryer for the past 3 months and manually been defrosing it weekly. it is a pain, but I have been able to keep my milk cold...
I would remove the evaporator cover and check the heater should be around 20 ohms. Also check the defrost thermostat should be 0 ohms when frozen. Note that it opens just above freezing so it must be frozen when you check it. Sometimes you can see it is shot if it is bulged out.
If both are OK then odds are it is the board.
If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range.
There is a good STICKY at the start of this forum about it's use. |
