David R
#1 Posted : Wednesday, December 16, 2009 10:18:14 AM(UTC)
David R
My freezer will not defrost on its own. I need to order and replace the control board. Does nayone know the cost of the part and where I can order one?
Thanks,
David
#2 Posted : Thursday, December 17, 2009 5:30:17 AM(UTC)
A Model Number may help others help you.
Model Number Locator
David R
#3 Posted : Thursday, December 17, 2009 7:21:37 AM(UTC)
David R
The Model number is PSF26NGPA BB
#4 Posted : Thursday, December 17, 2009 7:39:02 AM(UTC)
Replacement parts for General Electric PSF26NGPABB Refrigerator | AppliancePartsPros.com
Control Board is Item 801 in Section 2
I assume you have already checked the heater and the defrost thermostat
David R
#5 Posted : Thursday, December 17, 2009 8:04:24 AM(UTC)
David R
Thank you for your help. I was told by a GE "repair man" that it was the controller board. He said they fail all the time. He wanted $700.00 to replace it. When I said no, he offered to come back the next day and fix it for 400.00. He charged me $100.00 for the diagnosis... So honestly I am not sure of what is broken? He never took anything apart. He just looked at the fost on the back of the freezer wall.
The freezer does not defrost, that is all I know and I can only aford about $200.00 to fix it. I have been using a blow dryer for the past 3 months and manually been defrosing it weekly. it is a pain, but I have been able to keep my milk cold...
#6 Posted : Thursday, December 17, 2009 5:42:46 PM(UTC)
I would remove the evaporator cover and check the heater should be around 20 ohms.
Also check the defrost thermostat should be 0 ohms when frozen. Note that it opens just above freezing so it must be frozen when you check it. Sometimes you can see it is shot if it is bulged out.
If both are OK then odds are it is the board.
