tek
#1 Posted : Wednesday, December 16, 2009 9:23:03 AM(UTC)
tek
This washer knocks when the drum is spinning. Depending on the speed the knocking gets louder/more frequent.
I took the back panel off, and the knocking sounds it is coming from the inside the Rear outer tub assembly (shell) right in the back of if where the Pulley - drum - reinfor is mounted.
What can cause this knocking? There seem to be only 2 parts that have the potential to make this noise; the outer and Inner tub assembly with spider and shaft. Which one these could be the problem?
#2 Posted : Wednesday, December 16, 2009 12:32:03 PM(UTC)
Probably a busted spider support, eventually another one will break and the spin basket will no longer spin. I assume you checked the shocks and support springs.
tek
#3 Posted : Wednesday, December 16, 2009 1:34:43 PM(UTC)
tek
What are the chances that the outer assembley needs to be replaced as well?
Since I can not get the spider by itself, I have to ge the whole: Inner tub assembly with spider and shaft. correct?
Yes I have, no problems there.
Sounds pretty final! :-)
thanks
#4 Posted : Wednesday, December 16, 2009 3:45:52 PM(UTC)
Fast becoming a item to be thrown out.
tek
#5 Posted : Thursday, December 17, 2009 5:16:28 AM(UTC)
tek
I ran the washer one more (final) time, and now I see some plastic shavings in the main drum (mixed with the clothes)... I do not think that this is a coincidence.
Fat lady has sung....
#6 Posted : Thursday, December 17, 2009 12:05:57 PM(UTC)
Not good with plastic shavings, I gues it's better than grease from the bearings. I would assume your tub bearings are going out also.
