OK so I disassembled my dryer to replace the heating element and that went fine, problem is when I went to reassemble I realized I have no Idea what wires to attach were on the timer. I have A, B, C, F, T, & X connectors and Orange(12), Red(12), Brown(14), and Yellow(14) wires.
Any help would be greatly appreciated!
Ok through trial and error I have found the correct wiring combination. From top left to right it goes... Brown, Red, Orange. With bottom left yellow. I hope this helps someone else out cause finding that out was a nightmare.
