txjoe_99
#1 Posted : Tuesday, December 15, 2009 3:22:07 PM(UTC)
txjoe_99
The dishwasher tub fills with water, a motor hum comes on and the element heats up. It doesnt seem to do anything else. the timer seems to get stuck on 76...any ideas would great.
Thanks,
Joe
txjoe_99
#2 Posted : Tuesday, December 15, 2009 8:18:02 PM(UTC)
txjoe_99
ok... upon doing some research and a little tinkering, i found that my chopper motor was frozen up. I was able to free it up and get it to work... well kind of! Now its making a aweful grinding sound. I would assume that this is the motor going out? Anyone know where i can find the part and maybe some instructions on how to change it out?
Thanks in advance!
Joe
KE5ZKD:)
#3 Posted : Thursday, December 17, 2009 12:48:32 AM(UTC)
Replacement parts for gu1500xtk models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208533399.pdf
And a manual
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Could be the motor but I would pull it apart and check the impeller etc. before ordering parts.
txjoe_99
#4 Posted : Thursday, December 17, 2009 2:42:40 PM(UTC)
txjoe_99
Originally Posted by: denman Go to Quoted Post
And a manual
Thanks for the info! I am going to pull it out this weekend and dig into it deeper.
:D
