The ignitor lights. the gas dont pick up, after about 20-30 sec the ignitor lights again but the gas still dont pick up. So the dryer dont work. What is most likely the problem?
Originally Posted by: jacksa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The ignitor lights. the gas dont pick up, after about 20-30 sec the ignitor lights again but the gas still dont pick up. So the dryer dont work. What is most likely the problem? the dryer dosnt pick up the gas, so the dryer dosnt get warm, the ignitor does work
Assuming there is gas to the dryer and gas shut off valve is open, most likely the problem is a bad gas valve coils (#13 & #14 on the diagram). - The coil kit Part number: AP3094251
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Assuming there is gas to the dryer and gas shut off valve is open, most likely the problem is a bad gas valve coils (#13 & #14 on the diagram). - The coil kit Part number: AP3094251
Thanks! so I shoud buy only part # AP3094251? What about parts 13 and 14? you wrote?
This is the kit which included both coils.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) This is the kit which included both coils.
Gene. Hi again. It might sound like a silly question...why do I need a kit ot 2 coils? I see in the back only 1 black coil? also, I see im ******** part # 279834 of Maytag, for $5.95 plus s/h is it the same as Whirpool #AP3094251 for $14.95 plus s/h. But each part 13 or 14 as you mentioned is $23.95 plus s/h, I'm confused. Which part should I buy? how many coils do I have to replace? where are they?Thanks!
