jacksa
#1 Posted : Tuesday, December 15, 2009 12:06:24 PM(UTC)
jacksa
The ignitor lights. the gas dont pick up, after about 20-30 sec the ignitor lights again but the gas still dont pick up. So the dryer dont work. What is most likely the problem?
jacksa
#2 Posted : Tuesday, December 15, 2009 12:21:27 PM(UTC)
jacksa
the dryer dosnt pick up the gas, so the dryer dosnt get warm, the ignitor does work
#3 Posted : Tuesday, December 15, 2009 2:02:15 PM(UTC)
Assuming there is gas to the dryer and gas shut off valve is open, most likely the problem is a bad gas valve coils (#13 & #14 on the diagram).
- The coil kit Part number: AP3094251
jacksa
#4 Posted : Tuesday, December 15, 2009 3:23:56 PM(UTC)
jacksa
Thanks! so I shoud buy only part # AP3094251? What about parts 13 and 14? you wrote?
#5 Posted : Tuesday, December 15, 2009 3:59:15 PM(UTC)
This is the kit which included both coils.
jacksa
#6 Posted : Tuesday, December 15, 2009 11:10:46 PM(UTC)
jacksa
Hi again.
It might sound like a silly question...why do I need a kit ot 2 coils? I see in the back only 1 black coil? also, I see im ******** part # 279834 of Maytag, for $5.95 plus s/h is it the same as Whirpool #AP3094251 for $14.95 plus s/h. But each part 13 or 14 as you mentioned is $23.95 plus s/h, I'm confused.
Which part should I buy? how many coils do I have to replace? where are they?Thanks!
Guest (6)
