Could it just be dripping from the door and wicking down? Yes.
If it's level will it stop? A good possibility. It may not leak when full but once the pump starts up it may be sloshing over. It should be level or even tilted towards the back slightly. You will not know till you level it. Also clean inside the tub under the door.
I would repair this ASAP as it is may be leaking into the power connection box. |
THIS FORUM IS DEAD!!!!!!! |
