DIYmo
#1 Posted : Monday, December 14, 2009 5:00:42 PM(UTC)
DIYmo
Great dishwasher, rack roller rusted through, so we pulled it out and replaced the bolt. Had to cut the leveling feet off to get it out, now it leaks just a bit under part 28 Frame and tank replacement parts for WHIRLPOOL KUDJ230Y2 | AppliancePartsPros.com.
Could it just be dripping from the door and wicking down? Only leaks when motor is running, not when filling.
If it's level will it stop?
#2 Posted : Tuesday, December 15, 2009 1:30:36 AM(UTC)
Yes.
A good possibility.
It may not leak when full but once the pump starts up it may be sloshing over.
It should be level or even tilted towards the back slightly.
You will not know till you level it.
Also clean inside the tub under the door.
I would repair this ASAP as it is may be leaking into the power connection box.
