:mad: washer fills, motor just buzzes after that will not run in any cycle. could it be motor switch,,,, or motor$$$$.
First thing I would do is check to see if something is stuck in the pump ... This would cause your motor to not turn and buzz like you discribed
nothing in pump,,, changed coupler,,,, ran till i shut it off,, then buzzing again,,, lol i'll take it apart again and look at trany. all that is left i guess. ty. if u think of anything else give me a shout,, ty again
If your pump and tranny turn in both directions freely, I would look into possible low or no voltage at your motors start capacitor. (shown below) Back to Results Capacitor Part Number: AP3866194 Made by WHIRLPOOL Our Price: $20.80 Compare at: $31.96 You Save: $11.16 In Stock Order now and it will ship Tuesday Quantity
if the capacitor is at fault whould the motor run hot???
With the motor disconnected from the pump and tranny, does it turn freely by hand in both directions?
Your motor will get hot if tries to start and cant due to a start capasitor issue... I would test it first before we say your motor needs to be replaced.
had the motor tested,,,,poof,,,, lol,new one works just fine,,,ty for your help,,, great site. thanks , awelsh.......
Your welcome ...Im glad we could help
