I don't seem to have power to the dispenser. Light doesn't work, checked it and is ok. Took panel off and saw a microswitch for each dispenser, could both be out at same time, any help is appreciated.
Thanks, Pat
Not sure about the light but I know the dispensers won't operate if the door switch is defective or the door is not engaging it properly to close the circuit.. I once found a misaligned door causing this problem... kooler
Thanks, I saw that on another post, had light switch tested they said it was ok.
