PatM
#1 Posted : Thursday, March 13, 2008 3:49:32 PM(UTC)
PatM
I don't seem to have power to the dispenser. Light doesn't work, checked it and is ok. Took panel off and saw a microswitch for each dispenser, could both be out at same time, any help is appreciated.
Thanks, Pat
kooler
#2 Posted : Friday, March 14, 2008 9:28:49 AM(UTC)
kooler
Not sure about the light but I know the dispensers won't operate if the door switch is defective or the door is not engaging it properly to close the circuit.. I once found a misaligned door causing this problem... kooler
PatM
#3 Posted : Friday, March 14, 2008 4:19:57 PM(UTC)
PatM
Thanks, I saw that on another post, had light switch tested they said it was ok.
