mrshakim
#1 Posted : Friday, December 11, 2009 3:53:25 PM(UTC)
mrshakim
How do you repair a broken water line on a side by side freezer door?
jeffrey_benjamin
#2 Posted : Friday, December 11, 2009 6:01:39 PM(UTC)
jeffrey_benjamin
Remove the door liner to get to the tubing:)
mrshakim
#3 Posted : Saturday, December 12, 2009 8:56:40 AM(UTC)
mrshakim
How do you remove the door liner?
jeffrey_benjamin
#4 Posted : Saturday, December 12, 2009 12:51:27 PM(UTC)
jeffrey_benjamin
How do you remove the door liner?[/quotewhat is the model # of ur refrigerator
phillcan5
#5 Posted : Saturday, December 12, 2009 1:07:36 PM(UTC)
phillcan5
Mine broke and it was easier than i expected the plastic tip broke off where it comes out the dispenser.So what i did is exposed enough hose to cut out the whole plastic piece.Then i found something to join the two hoses together(old to new)snugly then i pulled on the old hose at the bottom of the door to feed the new one thru piece of cake then you connect up the waterline at bottom of door and reattach back in the dispenser.
mrshakim
#6 Posted : Thursday, December 17, 2009 5:54:13 AM(UTC)
mrshakim
Thanks! It worked like a charm.
