pajoismaer
#1 Posted : Friday, December 11, 2009 3:14:16 AM(UTC)
pajoismaer
If the timer is turned to the rinse cycle manualy after the dry cycle is done it will drain and dry.
#2 Posted : Saturday, December 12, 2009 2:48:14 AM(UTC)
Pump and spray arm replacement parts for WHIRLPOOL DU890SWKQ0 | AppliancePartsPros.com
Here is the tech sheet and a manual
http://www.servicematters.com/d...0Sheet%20-%208275136.pdf
https://secured.whirlpoo...510938/$FILE/4322430.pdf
Check/clean the drain system
Check/clean the pump
If both the above are OK then it could be the timer.
pajoismaer
#3 Posted : Saturday, December 12, 2009 2:58:53 AM(UTC)
pajoismaer
pump will function if i manualy turn to rinse after the cycle is finished it drains
#4 Posted : Sunday, December 13, 2009 3:04:08 AM(UTC)
Yes, but what can happen is that through the cycle it does not drain out all the water so in builds up and after the last drain you see the accumulation.
