If the timer is turned to the rinse cycle manualy after the dry cycle is done it will drain and dry.
THIS FORUM IS DEAD!!!!!!! |
pump will function if i manualy turn to rinse after the cycle is finished it drains
Yes, but what can happen is that through the cycle it does not drain out all the water so in builds up and after the last drain you see the accumulation. |
