First, than you for all the great advice you give. It is very much appreciated.
I have error code F1 E2 on my Whirlpool range. I see from the list this means the ERC needs to be replaced. Do you know if this model has botht he ERC and touchpad as 1 assembly? I had read that some models have htis as 1 assembly which means both get replaced and there is no need to test to see if it is the touchpad or ERC which is the problem. Is this repair something I or my semi handy husband can do ourself?
THIS FORUM IS DEAD!!!!!!! |
