LisaF
#1 Posted : Thursday, December 10, 2009 8:25:29 AM(UTC)
LisaF
First, than you for all the great advice you give. It is very much appreciated.
I have error code F1 E2 on my Whirlpool range. I see from the list this means the ERC needs to be replaced. Do you know if this model has botht he ERC and touchpad as 1 assembly? I had read that some models have htis as 1 assembly which means both get replaced and there is no need to test to see if it is the touchpad or ERC which is the problem.
Is this repair something I or my semi handy husband can do ourself?
#2 Posted : Friday, December 11, 2009 4:42:35 AM(UTC)
Replacement parts for RF368LXKT models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208053296.pdf
Here is a manual to help replace it
https://secured.whirlpoo...5ef62c/$FILE/8178042.pdf
Just a Control (ERC), take a look at Item 12 in Section 2.
Click on the picture and it will give a larger view.
I guess the operative word here is "semi".
I can see no reason why not, the manual should help.
Just take your time and remember to unplug the unit while working on it!!
First, I would try removing power from the unit for half an hour or so and retrying it.
Sometimes electronics can hang up and removing power will reset them.
Whirlpool stove/range (Oven Repair (including Ranges and Cooktops))
by hillji 11/5/2017 2:52:32 AM(UTC)
