Yam
#1 Posted : Wednesday, December 9, 2009 12:19:07 PM(UTC)
Yam
Hi... I'm really hoping you can help me here!!! When I press the bake switch the bottom oven element does not come on. So I replaced the element thinking that would solve it but that didn't work, now someone said it was the card which is not sending the command. What do I do or what do you think is the problem because all sales are final on the parts???
#2 Posted : Wednesday, December 9, 2009 2:49:49 PM(UTC)
If there is nothing wrong with the heating element and wires, then the problem most likely is a bad control board aka a clock.
If you need the correct part number, post the end of the model number and color of the key pad.
