Hi... I'm really hoping you can help me here!!! When I press the bake switch the bottom oven element does not come on. So I replaced the element thinking that would solve it but that didn't work, now someone said it was the card which is not sending the command. What do I do or what do you think is the problem because all sales are final on the parts???
If there is nothing wrong with the heating element and wires, then the problem most likely is a bad control board aka a clock.
If you need the correct part number, post the end of the model number and color of the key pad.
