I have a maytag atlantis I have just replace the timer on it but I am still having the same issue I did before......It run great it the stopping that seams to be an issue for the dryer.... It won't stop I have to open the door to shut it off.....I have tried to put it on the timed dry and also on the intelidry.....I am just curious if anyone out there knows how to fix this problem. Thank you very much for your time.
THIS FORUM IS DEAD!!!!!!! |
yeah the timer isn't advancing on any setting I have cleaned the sensor but nothing is helping. I will buy the control board next thanks.
