AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Jenn-Air start light not turning on, touch panel or control board?
My control panel had stopped working and I tried turning off the breaker for a couple of days, no luck, then I took the dishwasher apart and did what Denman suggested. It seemed very simple was not sure if it would work, so I waited over 6 weeks until I did finally did it.
It worked, I just ran a full cycle. I will run it again with dishes later today.
Thank you Denman for your help. :) [/SIZE][/FONT]
Christiana Seattle WA
I have the same problem, but turning off the breaker or replacing the touch panel did not do anything. This all started after I got some water into the door (poor gasket installation) and opened the door. I suppose I could have damaged something either while taking the door apart, or because of water.
Control panel seems sealed enough, so does not seem likely that it's the problem. I checked the contacts. Don't know what else I can check :(
I wonder if something could have gone wrong with the door switch? (My start button used to light up before you close the door)
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello I have a Jen Air # JMC9158AAS everything works except the background lights on the push button panel we have to use a flashlight to see what we want to do.
Dishwasher Repair
