2 Pages<12
christianausa
#11 Posted : Wednesday, October 8, 2014 11:45:08 AM(UTC)
christianausa
My control panel had stopped working and I tried turning off the breaker for a couple of days, no luck, then I took the dishwasher apart and did what Denman suggested. It seemed very simple was not sure if it would work, so I waited over 6 weeks until I did finally did it.
It worked, I just ran a full cycle. I will run it again with dishes later today.
Thank you Denman for your help. :) [/SIZE][/FONT]
Christiana
Seattle WA
losangelesdweller
#12 Posted : Sunday, May 15, 2016 7:50:56 PM(UTC)
losangelesdweller
I have the same problem, but turning off the breaker or replacing the touch panel did not do anything. This all started after I got some water into the door (poor gasket installation) and opened the door. I suppose I could have damaged something either while taking the door apart, or because of water.
Control panel seems sealed enough, so does not seem likely that it's the problem. I checked the contacts. Don't know what else I can check :(
I wonder if something could have gone wrong with the door switch? (My start button used to light up before you close the door)
Guest
#13 Posted : Thursday, December 28, 2023 3:00:30 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Hello I have a Jen Air # JMC9158AAS everything works except the background lights on the push button panel we have to use a flashlight to see what we want to do.
2 Pages<12
