Hello All!
My problem began intermittently, but now happens every time we use this oven. The oven get to the set temperature but within 15-20 minutes the screen goes blank and the element shuts off. The fan continues to run. This happens in all cooking modes. Giving the touchpad a wack sometimes turns it back on, but the symptoms repeat themselves. It started in the top convection oven, but has now spread to the lower standard oven. I replaced the touchpad about two years ago. Anyone have a clue? Thanks in advance!
Brian
Hi Brian, Most likely the problem with your oven is a bad control board which has to be replaced. The new board comes with the installation instructions. - The part number for the control board is AP3155970 . Here are the break down diagrams for the GE oven Model JTP56WA1WWGene.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
That’s not gonna be the problem I have had to replace my control board three times and I’m still having a problem this is just a very poor and badly manufacturer product and GE need to have a recall on it.
Sorry to hear it. What is the complete model number of the oven? Also can you please describe the problem more specific? Thank you.
Rank: Guest
Hi there. GE electric range, about 12 years old. Been workign perfectly until 2 weeks ago. Model JCB968. Oven gets heated and then randomly shuts off, like you had never set anything. I thought someone in the family was shutting off the oven. Any idea what is wrong? Thanks Edited by user Thursday, May 6, 2021 6:39:00 PM(UTC)
| Reason: Not specified
Rank: Guest
I’m having the same issue with my oven. I’ve had the control board replaced twice. The oven is less than 10 years old.
Rank: Guest
Same here. PTS700SNSS, just over a year old. Had the control board replaced twice now.
