svmhill06
#1 Posted : Sunday, December 6, 2009 3:28:09 PM(UTC)
svmhill06
The coils on the bottom of my oven donot get hot,only the top coils work.:confused:
#2 Posted : Monday, December 7, 2009 3:51:46 AM(UTC)
Replacement parts for FRIGIDAIRE FEF326ABK Frigidaire/electric Range | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...pringfield/316218512.pdf
Here is a good site with general repair help
http://www.applianceaid.com/elecrange.html
Could be that the bake element has burned out.
Could be other things but this is the most likely.
Unplug the unit and remove the bake element.
Measure it with a meter usually around 20 ohms.
If open (infinite ohms) it needs replacing.
It is a good idea to clip something (clothes pin etc.) onto the element wires so they do not disappear back into the unit.
