The coils on the bottom of my oven donot get hot,only the top coils work.:confused:
Here are your parts Replacement parts for FRIGIDAIRE FEF326ABK Frigidaire/electric Range | AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/p...pringfield/316218512.pdfHere is a good site with general repair help http://www.applianceaid.com/elecrange.htmlCould be that the bake element has burned out. Could be other things but this is the most likely. Unplug the unit and remove the bake element. Measure it with a meter usually around 20 ohms. If open (infinite ohms) it needs replacing. It is a good idea to clip something (clothes pin etc.) onto the element wires so they do not disappear back into the unit. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
