AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Will not Drain and Control panel just clicks with nothing in number window?
My dishwasher will not drain. It just clicks inside but nothing happens. In the front window of cycle countdown, there is no reading or problem code. Could someone give some ideas?
Is the water hot as usual. Does it shut off or just keep running longer than usual? Do you have a Cancel/Drain option to abort washing cycle?
Originally Posted by: sbk101 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Is the water hot as usual. Does it shut off or just keep running longer than usual? Do you have a Cancel/Drain option to abort washing cycle? It does not shut off. It just stopped. I do have cancel drain, but none of the buttons on the panel work. It sounds like the pump inside just clicks. I got all the water out removed bottom, with no sign of obstruction. If it is the pump, why is there signal to control panel???
Could you elaborate "why is there signal to control panel"? If it just stopped, are there signs of life? Bosch has issues with control module/circuitboards, but there may be obstructions other than inside machine, such as drain hoses, etc. Bosch Dishwasher Drainage Problem Fixes
Originally Posted by: sbk101 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Could you elaborate "why is there signal to control panel"? If it just stopped, are there signs of life? Bosch has issues with control module/circuitboards, but there may be obstructions other than inside machine, such as drain hoses, etc. Bosch Dishwasher Drainage Problem Fixes If I turn it on it sounds like the pump just makes a clicking sound as if it was pumping but no water is pumping out. So i hand pumped out the water and cleaned out the basket. I removed the bottom and checked all the hoses for clogs. the front panel does not light up at all. Could it possibly be the circuit board?
Dishwasher Repair
