14theirish
#1 Posted : Sunday, December 6, 2009 11:35:00 AM(UTC)
14theirish
My dishwasher will not drain. It just clicks inside but nothing happens. In the front window of cycle countdown, there is no reading or problem code. Could someone give some ideas?
sbk101
#2 Posted : Monday, December 7, 2009 7:20:30 AM(UTC)
sbk101
Is the water hot as usual. Does it shut off or just keep running longer than usual? Do you have a Cancel/Drain option to abort washing cycle?
14theirish
#3 Posted : Monday, December 7, 2009 7:48:03 AM(UTC)
14theirish
It does not shut off. It just stopped. I do have cancel drain, but none of the buttons on the panel work. It sounds like the pump inside just clicks. I got all the water out removed bottom, with no sign of obstruction. If it is the pump, why is there signal to control panel???
sbk101
#4 Posted : Monday, December 7, 2009 7:53:35 AM(UTC)
sbk101
Could you elaborate "why is there signal to control panel"?
If it just stopped, are there signs of life?
Bosch has issues with control module/circuitboards, but there may be obstructions other than inside machine, such as drain hoses, etc.
Bosch Dishwasher Drainage Problem Fixes
14theirish
#5 Posted : Monday, December 7, 2009 8:09:04 AM(UTC)
14theirish
If I turn it on it sounds like the pump just makes a clicking sound as if it was pumping but no water is pumping out. So i hand pumped out the water and cleaned out the basket. I removed the bottom and checked all the hoses for clogs. the front panel does not light up at all. Could it possibly be the circuit board?
