Replacement parts for MAGIC CHEF 6898VRV Range - S/c S/i Ele | AppliancePartsPros.comWhen the original element melted down, is there another part that I might also need to replace or is it possible that the "new element" is defective?
Is there a way to test this? A defective part is always a possibility. Unplug the unit, remove the element and check it with a meter. They are usually around 10 ohms.
There is something under the cooktop that is labeled a switch-snap acting...is this the same as a thermostat and could it have blown when the original element went? I would say that it is a thermostat/thermal cut-off. But without a wiring diagram I cannot say what it is doing. It is possible that it is just for the bake element.
Unplug the unit and measure it with a meter, should be 0 ohms.
Is there a diagnostic process to go thru to figure this out...can I take the broiler connections and put them on the oven element to see if it heats? You could but it is easier and safer to use a meter.
240 volts is lethal.
If the above are OK then it becomes a crap shoot.
This unit uses a control board and a relay board. Without a wiring diagram it is difficult to diagnose the cause so the below is just supposition.
It looks like the relay board has the power supply to run the control board and the relays to run the oven elements.
If when you try bake you can hear the relay click in but the bake element does not come on then the odds are that it is the bake element relay that is shot and the relay board needs replacing
A couple things to note is that during preheat for bake most units alternate between the bake and broil elements to give a faster preheat.
Also the relay board has a third relay which may switch between the elements.
Just mentioned the above because it may be difficult to know which relay is closing for just the bake element.
Hopefully someone else will jump in with a wiring diagram or knowledge on this specific unit.
