Lawrence Bronson
#1 Posted : Friday, December 4, 2009 8:53:57 AM(UTC)
Lawrence Bronson
Washer will fill but won't agitate, or it will agitate and not go into the spin cycle. I ordered a new control assy. from Appliance Parts Pros and installed the part, and the washer still won't complete a full cycle. Any ideas?
sidfink43
#2 Posted : Saturday, December 5, 2009 5:35:45 PM(UTC)
sidfink43
Unfortunately GE will not release technical data to the outside, so I can only give you the generic answer, which is to check all of the wiring. There may be a frayed or partially broken wire or connection which is causing your problem. I would take off the wire harness at the motor and clean the contacts with eletrical contact cleaner also.
Hope this helps.
Lawrence Bronson
#3 Posted : Sunday, December 6, 2009 12:42:50 PM(UTC)
Lawrence Bronson
Checked the wires to the capacitor where I foud a a bad connection. Thanks for the help. It now works fine.
sidfink43
#4 Posted : Sunday, December 6, 2009 1:27:56 PM(UTC)
sidfink43
Great, glad that worked and that you got it going without any cost for parts or that expensive tech visit.
Thanks for the update.
