Hi Guys I do have problem with my Maytag Oven. This oven is devited into two area one "upper" is a small and "lower" is a large baking area. In my case the upper area is NOT working any more. The lower area still no problem and also four burners for cooking are no problem. Anyway is somebody will give me tips where I should start and what should be check first I will be very appreciated Thanks Ted
Most common problem in this scenario is faulty ignitors. You need to check if they are red which would mean they are working. If ignitors are ok then the problem is either with safety valve or electronic control board. It's impossible to check if safety valve is working or not but it's cheaper to try replacing it first. Electronic control board is the most expensive of them and should be tried last.
Hope this helps, Dmitriy
Great thanks One more think. Where I find any manual for this Range? Ted
