Tadek
#1 Posted : Saturday, March 8, 2008 6:36:18 AM(UTC)
Tadek
Hi Guys
I do have problem with my Maytag Oven. This oven is devited into two area
one "upper" is a small and "lower" is a large baking area. In my case the upper area is NOT working any more. The lower area still no problem and also four burners for cooking are no problem. Anyway is somebody will give me tips where I should start and what should be check first I will be very appreciated
Thanks Ted
Active Appliance
#2 Posted : Saturday, March 8, 2008 8:23:01 AM(UTC)
Active Appliance
Most common problem in this scenario is faulty ignitors. You need to check if they are red which would mean they are working.
If ignitors are ok then the problem is either with safety valve or electronic control board. It's impossible to check if safety valve is working or not but it's cheaper to try replacing it first. Electronic control board is the most expensive of them and should be tried last.
Hope this helps,
Dmitriy
Tadek
#3 Posted : Saturday, March 8, 2008 7:25:48 PM(UTC)
Tadek
Great thanks
One more think. Where I find any manual for this Range?
Ted
Active Appliance
#4 Posted : Monday, March 10, 2008 8:26:44 AM(UTC)
Active Appliance
This is what I found by searching Maytag web site.
Maytag Product Literature Search Results
Hope this helps,
Dmitriy
