So I have been reading through the posts and I have an Ice maker that will not dispence water in the tray. Optics tested ok, jumped the thermostat to start a new cycle and worked except it did not dispense water. jumped the water valve and it sent water to the ice tray. My refrigerator is a Kenmore elite 106.56689502 side by side. From what I understand is that the ice maker modual is not sending the signal to the water valve to open and let the water flow to the ice tray. Am I correct? How to fix? Thanks Mike
