Our GE Profile Space-maker XL1800 when run at full power shuts off in 2-4 seconds and displays power interruption. The display flicker also when it shuts off. If you start it at power level of 8 it works fine.
Originally Posted by: jerryxl1800  Our GE Profile Space-maker XL1800 when run at full power shuts off in 2-4 seconds and displays power interruption. The display flicker also when it shuts off. If you start it at power level of 8 it works fine. Mine does the same. Have you found a fix for it? I've called a service repairman and will post if/when I get new information.:)
Our microwave makes a very loud noise when running. Is this repairable?
Originally Posted by: joyce mix  Our microwave makes a very loud noise when running. Is this repairable? We have a similar problem. The noise is like a growling noise. I remove the 'lazy susan' dish on the inside, and it still makes the same noise. Have you had any luck dealing with it?
