denton
#1 Posted : Wednesday, March 5, 2008 10:20:40 AM(UTC)
denton
My Kenmore direct drive washer doesn't spin fast enough during spin cycle to take the water out. Clothes are really wet if it is a full load of clothes. Everything else appears to be working OK.
#2 Posted : Wednesday, March 5, 2008 5:21:02 PM(UTC)
Remove the washer cabinet and check for a clothes between the inner and the outer tubs.
If there is nothing and you did not overload the washer, then most likely the problem is a bad clutch.
- The part number for the clutch is AP3094537
Maytag Washer -- Clothes Wet After Spin Cycle (Washer Repair)
by Frenchy7 7/5/2016 9:41:48 AM(UTC)
washer leaves clothes wet after spin cycle (Washer Repair)
by ginger919 3/10/2015 6:43:04 AM(UTC)
