My Kenmore direct drive washer doesn't spin fast enough during spin cycle to take the water out. Clothes are really wet if it is a full load of clothes. Everything else appears to be working OK.
Remove the washer cabinet and check for a clothes between the inner and the outer tubs. If there is nothing and you did not overload the washer, then most likely the problem is a bad clutch. - The part number for the clutch is AP3094537 Gene.
