lovenaz1940
#1 Posted : Saturday, November 28, 2009 11:00:33 AM(UTC)
lovenaz1940
I got an auto shut-down. Assumed the problem was the broken door latch, which I replaced.
The unit fills and starts normally but after 3-5 secs. the moter shuts-down. After about 30 secs. it will restart and repeat the shut-down for 3 cycles before comlete shut-down occurs.
I thought it might be a motor overload or start problem but an amp check indicates 6 amps on start and 2 amps while running before shut-down.
What could be causing the moter circuit to drop-out? Since I dont have a wiring diagram I dont even know where to start. Any help will be appreciated,:confused:
#2 Posted : Sunday, November 29, 2009 12:52:37 AM(UTC)
Replacement parts for MAYTAG MDBTT59AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...heet%20-%20W10142800.pdf
Could be a water heating problem but strange that you do not get an error indication.
lovenaz1940
#3 Posted : Monday, November 30, 2009 6:35:29 PM(UTC)
lovenaz1940
thanks so much for the tech sheet, really helpful
I checked water temp= 135. Question Does the heating element operate during to initial fill cycle? I didn't detect any current, but I have to check futher.
Tech sheet refers to diagnostic cycle to check heater but I can't seem to get the touch pad to respond. Am I missing something? Pls. elaborate. Thanks in advance. Carl:confused:
2mezzmo
#4 Posted : Friday, May 7, 2010 5:43:35 AM(UTC)
2mezzmo
I am having sam problem, I thought I needed a new motor, am I on the right track?
Originally Posted by: denman Go to Quoted Post
2mezzmo
#5 Posted : Friday, May 7, 2010 5:49:02 AM(UTC)
2mezzmo
any help out there?
